pichoor of your side steering damper
- thumperslaw
On the bike. As need to fab bracket for the one am getting
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
Re: pichoor of your side steering damper
Not on the bike, but might help:
http://www.ebay.co.uk/itm/DAYTONA-STEER ... 607wt_1396
http://www.ebay.co.uk/itm/Honda-VTR1000 ... 400wt_1163
Or see if Sprint will do a bracket:
You can contact us by telephone, fax, e-mail or by post.
Telephone number: 01159103247
(8:00am-4:30pm UK time mon-fri)
Fax: 01159103248
Postal address:
Sprint Dampers UK LTD,
Unit 5 Trent South Industrial Park,
Little Tennis Street,
Colwick,
Nottingham,
NG2 4EQ.
E-mail address: info@sprintdampers.co.uk
Or Reactive's site:
http://www.reactivesuspension.com/steeringdampers.php
Lots of pics.
Fax: 01159103248
Postal address:
Colwick,
Nottingham,
NG2 4EQ.
Or Reactive's site:
Lots of pics.
- thumperslaw
One thing i need to ask is why the plate?
thought the damper is bolting on to the faring bracket/frame
K100 "flying brick"
K100 "flying brick"
- benny hedges
talking to a chap at southport last weekend and he mentioned he has a brand new ohlins damper fitting kit for a firestorm, never fitted.thumperslaw wrote:On the bike. As need to fab bracket for the one am getting
yours for a song.
pm me if you want his number.
sounded a genuine lad like.
The hole for the bolt in the frame is 2mm smaller than the inner diameter of the rose joint, so 3 choices.thumperslaw wrote:One thing i need to ask is why the plate?
1) drill & tap the frame.....the lug is quite small and there won't be much metal left
2) sleeve down the rose joint, or make a stepped bolt.......I don't have a lathe.
3) make an adapter plate out of sme 3mm stainless I had under my bench.
I chose 3), and it has the advantage that you can put a bend in it to help keep the rose joint closer to the centre of its movement.
- thumperslaw
benny hedges wrote:talking to a chap at southport last weekend and he mentioned he has a brand new ohlins damper fitting kit for a firestorm, never fitted.thumperslaw wrote:On the bike. As need to fab bracket for the one am getting
yours for a song.
Pm you have
K100 "flying brick"
K100 "flying brick"
I have all the brackets but no damper as sprint couldn't service it as it was to old
I'm still looking for a damper
160mm long
