- bluestoesonnose
Been laying on my back cleaning the underside with a tooth brush
wombles to that!bluestoesonnose wrote:Been laying on my back cleaning the underside with a tooth brush
I have eventually finished giving her a good birthday:-
Subframe removed and repainted
All electrical connectors removed, cleaned and remade if looking iffy
Swinging arm removed, powder coated and bearings replaced
Front fork bottoms repainted
Suspension linkages regreased and one linkage replaced
Calipers and pistons cleaned
Wheels resprayed and new bearings
New plugs, air and oil filters and oil change
Coolant drained, flushed and refilled- new bottom hose fitted
Choke cables replaced
Bellypan resparyed to match rear wheel
Valve clearances checked
Manual CCT check (no adjustment needed - again!)
Cracked fairing lugs repaired
Scottoiler rerouted
Headstock bearings re-greased and adjusted
Scottoiler rerouted
- bluestoesonnose
Very nice, but you could have cleaned the tyre fitting gunk off the tyres
Dunno why but I was expecting a black swining arm and fork lowers
Still needs a wash and polish but I was hungry at the time so that can wait till Mondaybluestoesonnose wrote:Very nice, but you could have cleaned the tyre fitting gunk off the tyres
turned up the tickover to try and stop the annoying fart it has at 2800 rpm......so far so good, 1400rpm it is then
Painted one side. Next side when I get the gasket! I need a new set of caps though
A layer of acid etch over a cleaned standard cover. Then used Holts beige metallic, 3 layers of laquer too. It should break up that side lovely
- bluestoesonnose
Really like that, does anyone know whats close to the standard Honda colour?
Engine Cover paint http://www.vtr1000.org/phpBB3/viewtopic.php?f=7&t=22444
bluestoesonnose wrote:Really like that, does anyone know whats close to the standard Honda colour?
Or the easy answer is ford graphite grey metallic
Edit: that's for the grey ones
How about nice and shiny ones??
They need finishing but are coming up well.
Everything good is bad
Everything bad is good
- tankslappa
Very nice... I've got to do something with mine, they're starting to look scruffy, the old alloy fluff is starting to appear.
I'd probably go with the painted finish, I'll never stay on top of the polished one and then they'd go fluffy too!
Is this very involved? Can you just remove them from the sides of the engine (after draining the oil and water) and then put them back (with a new gasket), or do you end up unbolting half of the rest of the bike in the process?
Now what colour? I'm half tempted to go yellow, to match the rest of the bike, just to make it really offensive! Oh, and the wheels will need doing (winter job)... Yellow too?
Okay, joking, not yellow... I promise.
While you can do a lot with the part off the bike without rushing - It's feasible to spray paint bit s & bobs on the bike if you don't skimp on preparation and make sure you thoroughly mask off the rest of the bike from overspray - using masking tape (blue type is good) and newspaper etc. If outside do on a clear dry day and leave required time before coats. If pushed you can accelerate drying times using a hair dryer
See the previous link to a thread I posted and in it is another link to BMW rider paining in situ a cover on his bike to what is involved.
