brake clutch lines
mark skett
brake clutch lines
Post by mark skett »
im in the process of fitting renthals.
the throttle and all wires fit fine but the brake and clutch pipes are to short.
i want to fit 1 long pipe for the clutch without the joint and 2 seperate brake lines also without the block joint thingy.
ive seen bikes with a double joint on the brakes so that the pipes are kept seperate
does this affect the braking at all
also were can i buy them from, done a search on ebay but had no luck
mark skett
Re: brake clutch lines
ooooops should of gone in workshop but to late sorry
