CLUTCH SLIPS AT HIGH REVS ONLY
Hi people!
i have a slight problem with my clutch! it slips at high revs but is fine punching through the lower revs!!
do i need new clutch plates or could there be another soloution! iv bled the resiviour to the slave so i dont no what else it could be! Any ideas???? answers on a postcard!
- thumperslaw
Re: CLUTCH SLIPS AT HIGH REVS ONLY
mine is also doing the same 7k onwards
I think it's the clutch fiber plates wearing out
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
yea that sounds about right! have you replaced yet? think i may order some tonight and see what happens!
- thumperslaw
going to take mine out and see what they are like first
K100 "flying brick"
K100 "flying brick"
- benny hedges
engine oil change before you start fkin about with the clutch ;)
changed oil and filter about 6 weeks ago!
Did you use a new brand of oil? fully synth and also halfords own brand semi make my clutch slip
- thumperslaw
Done mine two days ago with semi good oil. Still does it
Def clutch plates
Def clutch plates
K100 "flying brick"
K100 "flying brick"
i used silkoline super four semi synth! its what i was advised to use! im still thinking its the friction plates!
bollox to it im gona order some!
I am having exactly the same problem. Need to get around to changing the plates as well
- thumperslaw
Some times you can get away with sanding the steel plates to get rid of the "blue" on them. Helping some times
K100 "flying brick"
K100 "flying brick"
