CCT replacement/ alternator bungs
SMITH MEISTER
Re: CCT replacement/ alternator bungs
Post by SMITH MEISTER »
Yeah, I did think abt oil filler caps as a possible, but...
1: they are nearly all ally, so would be just as soft as the original
2: non of the ones i have seen are big enough (needs to be M30!)
3; I wanted to try & keep the OE look
Like I said, will keep at it untill i get an answer! :wink:
chelskitel
Post by chelskitel »
cybercarl wrote:Wow those slipper clutches look good. :wink: And those oil filler cap with dip sticks are cool, reasonable price as well. :thumbup: I wonder how accurate the dipstick is. It's a shame those flebay covers don't have the smaller timing mark cap. :thumbdown:
Have Fun
Just notice they are Yamaha oil caps. Will they fit out bikes?
I would love to put a dipstick in the storm pity its not possible.
Nearly dropped the bugger the other day checking the oil,wouldn't be so bad if You could see the window but You have to virtually lie down to see it properly.
"Youth would be an ideal state if it came a little later in life."
H.H. Asquith 1852-1928
I do lie down, have to give the window a good polish as well. With a lower fairing it's even worse. I need to cut a peep hole in mine to see it now as the fairing covers it. doh
Have Fun
Ah, should have explained. Don't use the dipstick ones, as fitted instead of the oil filler cap they will just hit the clutch. Not cool at all. What I had in mind was to cut the dipstick off; just use the head instead of the large inspection cap.
Any cap will fit if it has the correct thread- check these before fitting.
I believe the Storm one is M30, but haven't looked up pitch.
Prob 1.5 or 2mm.
SMITH MEISTER
Prob 1.5 or 2mm.
[/quote]
Hi Tony, the cap is M30 x 1.5mm thread.
The problem is, this size seems almost impossible to find "off the shelf". I Don't think there are any oil filler caps in this size, they are more like M25 or something similar.
As I said, I am trying to keep it looking as stock as possible, & also stainless rather than ally. If someone else can find a suitable replacement then that's fine, but I've spent best part of a week trawling the web with not much success :confused
I know the feeling, I have spent a build of of more than a week. Nothing to be found, I am shocked that no 3rd parties make stainless bits for either the oil cap or generator cover bolts or even billet caps for the suspension. 8O there's enough people making pre load adjusters and brake/clutch caps!
Little bits of bling these companies have missed. Mmmm
Honda C50/70/90 tappet cover cap uses this thread size.
Also this:
http://www.wemoto.com/bikes/Honda/CMX_2 ... _Cap_30mm/
How about this?
http://www.motopartsmax.com/index.php/m ... s_id/11105
Here's a list of the other Honda products that use the same cap:
http://www.powersportsplus.com/parts/de ... 1-670.html
SMITH MEISTER
Mmmmm, interesting thoughts there :think: Could be a way to go if my current investigations fail.
Thankyou tony, it's good to get another perspective on the problem. :thumbup:
gl_s_r
Post by gl_s_r »
Mr Tony Mon,
I was having a spare hour at work and knocked these up... did you want me to drop a set to you so you can try them and give me your views/opinions?
gl_s_r
Post by gl_s_r »
Sorry, forgot to add they are both made from titanium and NOT stainless, I know they are not what you are after in this link but wanted you to know that before you get them and get disappointed.. :(
playerone
Post by playerone »
gl_s_r wrote:Mr Tony Mon,
They look nice :Stewy:
They look good mate. How much will you selling them at?
+1 I like the the circle of holes around the hex slot as well, nice touch. :thumbup:
Now all we need is some for the swingarm pivots blanking caps. :wink:
Oh, yes, please. :clap:
I will happily evaluate a set of those....
Thanks, matey!
chelskitel
I would like a set if You have one spare.
How much are they. :Beer Popcorn:
