metal polishing addiction
i think i have become addicted to polishing metal, so far ive done the headstock, rearsets, levers, front brake calipers, im doing the swinging arm, rear caliper, rear footrest hangers. but my addiction stops at the frame, im not that sad lol. i do it all my hand with wet and dry, and then metal polish, none of this buffing shizzle
does anyone else share this addiction?
Re: metal polishing addiction
used to be but im now cured!! no more sunday afternoons in the garage covered in autosol and belgum polish!
ive been using Autoglym metal polish lately, a much better product to work with i find! and it smells soooooo good! every spare 5 minutes im doing it, im finishing my left caliper today
my bloody keys keep marking my headstock though
i did my blade frame and swing arm took daysmarravtr wrote:used to be but im now cured!! no more sunday afternoons in the garage covered in autosol and belgum polish!
autosol is good to get is shiny but to protect it belgum alu is great as it leaves a wax on it .
so only needed to buff it up once a month
headstocks simple, only use one bloody key!masterdave wrote:ive been using Autoglym metal polish lately, a much better product to work with i find! and it smells soooooo good! every spare 5 minutes im doing it, im finishing my left caliper today
mine name is martin and i to have a metal polishing addiction..........
tbh i ain't that bad, although this week i sandpaper/polished my magnisium front sprocket cover, i even sandpapered out the word magnisium, i stoppped at doing the same for the numbers 1 to 6..........
in my defence, i need to cut the spocket cover to fit my spondon frame, so while i'm at it i thought sod it wheres the polish.....
i think bsm is getting varied forms of ocd
steve
steve
More like mad cows disease lol
Well the cows will be up in hoofs when they see his leathers lol
i always wondered why when i rode thru the country lanes cows would run away in the fields, i mean sheep running away i understand
I don't clean mine let alone polish anything but I'm sure it was bazza who has a post somewhere about polishing his forks to a very shiny finish
took a bit or work tho.......
I did do a little polishing today
I have a polishing fetish, get satisfaction from doing it. What else you going to do on a Sunday afternoon other than polish.playerone wrote:I don't clean mine let alone polish anything but I'm sure it was bazza who has a post somewhere about polishing his forks to a very shiny finishtook a bit or work tho.......
Autosol from my experience is only any good when you use mechanical polisher, otherwise by hand it’s too aggressive, you need to get the active ingredients working and hand polishing does not do it.
I use Maguire’s Nxt Generation All Metal Polish to keep on top of the polished bits
Rub your hand up and down a pole with a cream till its all shiny.Snoogle wrote:Polish???![]()
Please define
bazza696 wrote:Rub your hand up and down a pole with a cream till its all shiny.Snoogle wrote:Polish???![]()
Please define
Ahhhh you have to be a wonker to be good at it....gotcha!
No wonder I had no idea wot u lot were on about
