Clutch Replacement
- benny hedges
Re: Clutch Replacement
best way m8 - what i do anyway.... blue hylomar on one side of the gasket, smear of grease on the other... it will seal bob on and if you do end up having to pop it off in the near future it will come away intact without damaging the gasket ;)
is pro rg2 grease ok or will i need a high melting point typebenny hedges wrote:best way m8 - what i do anyway.... blue hylomar on one side of the gasket, smear of grease on the other... it will seal bob on and if you do end up having to pop it off in the near future it will come away intact without damaging the gasket ;)
got a little of that left in tub would be good to not have to go out and buy some more stuff
thanks for help mate and txt
Does that basket look OK, I don't know if that's the norm for a storm as I have not had one off yet.
The centre nut should be "twatted", that is to make sure that nut never comes undone when riding. They come from the factory like that
yep, of course, alternative to cotter/split pin.The centre nut should be "twatted", that is to make sure that nut never comes undone when riding. They come from the factory like that
Not the centre nut, I'm referring to outside circumference of the clutch centre. Why is it not round.
Maybe that's exactly as it looks on storms or the angle of pic. Anyway can't be that distorted otherwise Seb would not have got the plates on.
it is round mate i just think its an illusion on the photo because of the inside of it sweeps in at either side you can see an even gap around the plates herecybercarl wrote:yep, of course, alternative to cotter/split pin.The centre nut should be "twatted", that is to make sure that nut never comes undone when riding. They come from the factory like that![]()
That's a relief. So you back up and running now then?
Not made a start back in the garage yet today, better get my butt in gear lolcybercarl wrote:That's a relief. So you back up and running now then?
just wish this bloody HEL clutch line would have come by now
i do like looking into an engine to get an idea on how it works
Suck, Squeeze, Bang, Blow.
i know thatcybercarl wrote:Suck, Squeeze, Bang, Blow.![]()
Carl wasn't talking about his engine, he was describing a Friday night out for him!
I don't think Lloydie was talking about engines either.
Well new clutch feels fantastic very happy
Thanks benny for the tips and advise mate also
just had one of those tony moments, just woke up not sure if i fully tightened the clutch spring bolts up or just did them by hand, i seem to remember getting so far and stopping for tea
wombles hell!
off with the case again tomorrow
wombles hell!
