CCT Oil leak
Flatline
CCT Oil leak
Post by Flatline »
Fitted some of Bazza's manual ccts last year, however I have notices a slight oil leak on the rear cct
Have tightened the lock nut but its still leaking
Your advice on rectifying the problem please
seb421
Re: CCT Oil leak
Post by seb421 »
Set to correct timing marks loosen them off and apply decent coat of loctite or similar product, that should suffice has worked fine for me mate
Sent from the Bat Cave via Cup and String
Re: CCT Oil leak
+1 on that. You will have to put some sealant along the thread. :wink:
Re: CCT Oil leak
+2. Back out the cct (with the engine set at rear TDC- remember you'll need to take the rear cam cover off to make sure you're at the correct TDC- then wind the bolt out 10-15mm and push silicon sealer into the thread all round. Wind it back in and re-tension.
chric
Re: CCT Oil leak
Post by chric »
cant you just use two spanners and losen one while holding the other and spread some on it like that thats info i got on here and it works fine?
chric
Re: CCT Oil leak
Post by chric »
And to add i had only done 14 mile
Re: CCT Oil leak
chric wrote:cant you just use two spanners and losen one while holding the other and spread some on it like that thats info i got on here and it works fine?
you need to get the loctite / sealant onto the main bolt thread, not onto the locknut,. If you are going to undo the main bolt, it will slacken the chain tension, and that should only be done at the correct TDC timing mark, or you will jump teeth and bend valves :(
Re: CCT Oil leak
It's best to put it back to TDC so the camchain is not under tension. There's less chance of the chain slipping a tooth and knocking the timing out that way when loosening off. :wink:
chric
Re: CCT Oil leak
Post by chric »
ok so if it was all set up spot on like it was as you helped with my motorbike man on phone which im very greatfull for :thumbup:
And the only problem was a slight seap of oil trickling down the thread.And it's stopped since I used the loctite stuff useing the above way mentioned have I to worry about any thing.
And should the cct of bazza's leak or in general are they all the same :?:
Re: CCT Oil leak
chris, all manuals will leak oil down the thread on the rear as it points down hill. if it is not leaking now, you have nothing to worry about :thumbup:
chric
Re: CCT Oil leak
Post by chric »
Nice one Thanks I can go for a spin now with out worrying again.
If you ever need favour repaying let me know wont be on knowledge though be free polish or wax :lol:
lumpyv
Re: CCT Oil leak
Post by lumpyv »
yeah mine leaked to start with. just backed it out a bit and put a tiny bit of silicone on it?
