I have just got a set of goodridge hoses race set up.
The rear went on great and bled with no problems at all, fitted the front with double banjo straight off the master cylinder and tried various washer options and ways off bleeding it through but with no joy.
To try and find out what was going on we even took the d.banjo off and started pumping the brake lever and only a very little trickle of fluid was coming through and yes there was fluid in the cylinder, we checked the 2" long pipe from the cylinder to the lever for blockages but nothing, it seems as there is a problem with the lever, but are we doing anything wrong, my friend is completely mistified by it
Any suggestions would be greatly appreciated!
