Fairing Indicators - help
tasum
Post by tasum »
Can anyone recommend some fairing indicators to fit in the fairing hole?
I've replaced my originals with the smaller type, but neither hole has the grommet and I'm thinking it will look neater if I can get some of those oval, amber indicators to fit in the hole. :D
If anyone can point me in the right direction as there are so many on evilbay.
slow is smooth, smooth is fast
Jazzscot
Re: Fairing Indicators - help
Post by Jazzscot »
I got ones very similar to these ones
Cat Eye Indicators
http://bit.ly/OCqDFs
I can't find the exact ones I got but they were only a tenner.
Everything good is bad
Everything bad is good
You can also get this type which have a higher profile and so can be seen from directly in front:
tasum
Post by tasum »
thanks for the help. i like those jazzscot, i'll have a think about the lens colour.
thanks tony, I had those on when it came to me so I'm looking for something different, but thanks for the heads up and for pointing out that they do have the advantage of being seen from the front, worth considering again
thanks :D
Flatline
Post by Flatline »
tasum
Post by tasum »
I was looking at a set of spacers to mount hte mini standard indicators, but looking at them I'm not sure they'll work as the fairing just has a hole and then somewhere to mount the indicator on the inside shell of the fairing.
Thinking the flush or the cats eye type might solve the problem. thanks for the links :D
Cat eye ones work a treat and cover the hole nicely. They just clamp against the fairing using a big plastic nut on the rear which squeezes it in place. :thumbup:
tasum
Post by tasum »
cybercarl wrote:Cat eye ones work a treat and cover the hole nicely. They just clamp against the fairing using a big plastic nut on the rear which squeezes it in place. :thumbup:
thanks, i think you and jazzscott have persuaded me, cheers for the help :)
Do you mean the large oval shaped ones that fit in the fairing hole or the inner ones. I would not worry about the inner ones but the larger outside ones would be good to have. You could fit cat eyes without them, but they do make them look better and also give them more support and take some vibration out. :thumbup:
As an alternative you could run some Black silicone around the edge, let it dry first, then fit the indi's
Don't forget if you go down the LED route you will need some inline resisters. :wink:
tasum
Post by tasum »
going for the bigger ones that fit outside the hole.
was looking at spacers but they won't work.
thanks again :)
tasum
Post by tasum »
I gone for these, not super high quality, but they do the job.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 0747245032
Took the inside off the fairing to make them easy to fit. Ok for under a tenner for the pair.
They cover the hole and have quite long cables, so an easy fit.
