Evening all,
while fitting my belly pan this evening, was thinking about changing my clutch line to braided, can this be done?
Clutch line
Re: Clutch line
http://www.ebay.co.uk/itm/S-S-Brake-Clu ... 803wt_1134
http://www.vtr1000.org/phpBB3/viewtopic.php?f=9&t=24373
Re: Clutch line
so thats a yes I can change it then lol
okie dokie, does it make any improvements in the clutch action?
Re: Clutch line
Re: Clutch line
No change in the action at all, purely cosmetic.
The advantage with changing brake lines is that the original lines swell slightly under the pressure of the brakes being applied.
However the clutch doesn't have a solid "stop" like the brakes do; the pads trying to push through the disc is pretty much what you'd call an "immovable object".
The clutch doesn't have a positive stop, it just opens the clutch pressure plate away form the clutch basket so as to to release the pressure against the springs. and so the line pressure is a fraction of what is experienced in brake lines. So fitting a line which won't expand as much as a standard line is a bit of a waste of money, as it's never going to be under enough pressure to stretch or swell, and so you'll notice no difference.
Hasn't stopped me fitting a lovely braided line to match the brake lines, though.
Bling!
Bling!
- thumperslaw
Re: Clutch line
I can do Hel lines alittle cheaper for people on here
Pm me for more details
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
Re: Clutch line
It does mean your fluid won't go black so quickly though. That's about it though.
'98 VTR (Red - the quickest)
'94 KTM LC4 400e
'69 Land Rover S2 Lightweight
Trowbridge & Surrounding Areas Lawn Mower Servicing & Repairs
'94 KTM LC4 400e
