At the moment I've reverted back to all four flashing fast.
cybercarl wrote:+1
I would agree with with that. We fitted resistors on BSM's bike and they don't flash at the appropriate rate. They are slower but still too fast. It's far simpler to just fit an LED Relay.![]()
Definitely better off with a electronic flasher module. Resistors work fine though - had my back ones on for ages with resistors. The resistor need to be in parallel with the indicator (one for each) to draw the same current as the bulb. If I remember rightly I used 7ohm/30W resistors.Image wrote:I have mini indicators on the back of my storm and standard on front so I bought and fitted a purpose built universal (supposedly) restrictor. Wired it up as per the instructions (simple enough). The result was front indicators flashing normally and rear ones not at all. So what went wrong?![]()
