Next on my maintenance list is fluids. Clutch first then Brakes. I have read loads of tips on changing the front and rear brake fluid, but there's nowt on this forum about changing the clutch fliud.
Sounds easy, is it? If so is it just a case of slacking off a bleed nipple, squeezing the clutch and keep it topped up until new fluid comes out?
By the way, where is the bleed nipple?
Any constructive advise will be appreciated
t00lkit (ironic isn't it!)
