Wires to brake light? Helllllp!
Re: Wires to brake light? Helllllp!
Here is mine
if you have a look a the wiring diagram the brown wire is for the lighting .
side light /dash lighs/tail light .
brake light switch is black-white/green
black-green/yellow
black-green/yellow
Thanks fellahs. Yep that did it. Once I knew for sure what the wiring was, even though it still didn't work I was able to explore other possible flaws while it was wired correctly. A blown fuse that had no sign of being blown (looked fine) and a switch cable that had pulled out some effecting the sensitivity to nil. Working fine now. Got a brake light now for 1st time
