bmw hotrod project "schnell Brutus"
- thumperslaw
Re: bmw hotrod project "schnell Brutus"
And burnt fingers
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
- thumperslaw
Set up poll
Please see what you think
K100 "flying brick"
K100 "flying brick"
What colour is the bodywork going to be? I almost selected Get the dam thing done
Proper hot rod, red wheels & white walls, but for best effect you need spoked wheels. You sticking blue spots in the tail light as well?
- thumperslaw
Black frame with bare alloy tank
Dull alloy stacks and casing
No other body work apart from that
Red wheels would look cool (maybe)
K100 "flying brick"
K100 "flying brick"
Yeh a bit of colour would be nice but you need an ally mudguard as well
- thumperslaw
Got alloy front mudguard
K100 "flying brick"
K100 "flying brick"
- thumperslaw
So got the sub frame sorted kinda, need to make some shock mounts up again and clean the welds up.
Apart from spraying it black am happy with the way it looks so far
More of the sub frame got the grinder
Mock up test
Cheap jig....
Weld in place for
Mock up test
Cheap jig....
Weld in place for
K100 "flying brick"
K100 "flying brick"
is that a car tyre?
- thumperslaw
No just bold as wombles motorcycle one
K100 "flying brick"
K100 "flying brick"
- thumperslaw
Busy day working on the shock mounts and sub frame again
Putting extra bars there to help cope with stress
Some bracing to and shock mount out of thick stainless steel
K100 "flying brick"
K100 "flying brick"
Coming on nicely :-)
- thumperslaw
The seat pan is made!
All I need to do is paint the sub frame to stop it rusting and get some seat foam
K100 "flying brick"
K100 "flying brick"
Is that an old FIAT X1/9 lurking in the back ground?
I had a T plate one when I was in my early 20s, great fun but it spent as much time being welded and having the engine rebuilt as it did on the road!...must have been the start of my habit for hairdressers cars
- thumperslaw
Tonight i've been messing around with wiring and removing lots of it. Wired the rear light and hide all wiring going to it.
Not sure what to do about the water header tank yet tho.... I've got a idea tho, along the lines of some vintage oil can...... I'll keep you posted
K100 "flying brick"
K100 "flying brick"
