This is how I got it
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/CEJosVgBWkKGrHqZjQE0D7-o91BNRmbnGQ_12.jpg)
It was a right heap of junk .
1k later and many mods
modifications are .
suspension / brakes
new standard rear shock 1000 miles ago
5mm rear shock spacer
1992 fireblade forks with weighted springs .
1992 fireblade yokes (trees)
renthal ultra low bars will bar clamps
braided brake lines front and back
braided clutch line
cosmetic
fireblade race front fender
renthal grips
r1 mirrors
hugger
belly pan
under tray
seat cowl
head light kit 100/90 bulb
led stop/tail bulbs
mini indicators
didgi gear indicator(so you can see what gear your in)
lots of stainless steal nuts and bolts
performance
quick action throttle
return throttle cable removed
lightened flywheel
2-1 exhaust with scorpion race can
k&n filter
dyno jet kit
-1 tooth front sprocket
manual ccts
r1 reg/rec
clutch spring washers
tps set to 430 ohms
69000 miles and counting
A nice clean fast black storm
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/c30201c9.jpg)
But Its had a hard life so now it's time for a update !
On the list of todo's this winter is
Remove and repair the bodywork.
Respray the bodywork .
Get both subframes powder coated along with other brackets.
Powder coat the wheels and fit new bearings and tyres .
Give the engine and frame a good clean .
Paint the frame satin black .
Tidy up the wiring loom .
That little lot should keep me busy over winter and hope to be back on the road for spring !.
To start I removed the bodywork
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/795C1C62-3723-4B56-BB51-48390759E1F7-2881-0000044EF6E09843.jpg)
And repaired the damaged/missing bits
I used plastex to fix them as its easy to use and clean up .
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/5F3A94B6-9EA8-4D59-81B8-6020B65D8698-270-00000018A2D08A72.jpg)
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/5C9C722D-47F8-49F4-ABF7-4470355FECED-270-00000018AC744C75.jpg)
Then I dropped them at the painters alone with this pic of how I want it .
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/securedownload.png)
Then i removed the rear subframe and the front end .
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/63AB33F4-2558-4AA2-B87A-70564EE5045F-270-0000001894C1BF48.jpg)
I then gave the frame and engine a good clean .
It was in a right state !
I made a start on preparing the frame for paint(hammerite satin black) I know it's not petrol resistant but it will do for next season as I plan on getting it powder coated when I get a younger replacement engine .
I started of with masking all the places I didn't want to get paint on (xmas wrapping paper was used as its cheap )
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/25E7F6F3-2D09-4AB1-A360-5F65AB40F67E-270-0000001F1AE4D9A1.jpg)
then i gave it a light dust coat to begin with so the paint will stick and also give me a better surface once keyed for the next few coats .
To days later and two more coats and it was done .
I just need to leave it now to harden off .
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/37E86EF2-7E88-4105-AF19-0197F47E8286-270-00000018D20BF299.jpg)
I gave the top yoke a coat of paint to ,so it will match the frame .
Next up while I was waiting for the paint to harden I removed the goodridge brake lines .
They are the older type without the protective coating .
As I'm on a tight budget so new ones are out of the question plus I have some shrink wrap And thought why not .
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/501E8864-3A82-49B8-AA69-FDB3D0B7EBD7-270-00000018EFC07CDF.jpg)
It wasn't easy to do but it worked and now they shouldn't scratch the new paint either on the frame or the newly painted fairing .
The front forks were also cleaned and peeped and given two coats of the same satin black paint .
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/C7120A3F-A654-4D69-ADE2-31E28F1B657B-270-00000018E09506B4.jpg)
![Image](http://i550.photobucket.com/albums/ii409/lloydiecbr/vtr1000%20firestorm/2999B6C2-EF29-4EC7-A014-0C6574019F21-270-0000001DEC9EA22C.jpg)
Next up is to remove the rear wheel and swingarm also the suspension linkages .
Then off with the front subframe
And get them to the powder coaters to be done in satin black .
