worried
worried
with all the talk of cct failure, just wondered if they should make a noise at all, as when ticking over i get no cam chain noise also at full chat i get no noise, but if i just give a short blip of the throttle at traffic lights say,when the revs drop back i get a takka takka then no noise doesnt do it all the time just ocasionaly, just paraniod re the stories ,advice welcome
Re: worried
yes on the overrun the cam chain will slap a bit even if the tensiooner is working.
but dont play roulette................just do the stopper mod and ride happy
Re: worried
thanks buddy planning on getting the stopper mod done keep reading the instructions till i get confident enough to do itAMCQ46 wrote:yes on the overrun the cam chain will slap a bit even if the tensiooner is working.
Re: worried
If you are getting worried when doing the mod I am sure one of us will be on line and can pm you a mobile number and talk you through it. Once you have seen it done it is easy
Re: worried
The stopper mod itself is really simple but you will need a key to lock it off so either borrow, make or buy http://www.ebay.co.uk/itm/281026278904? ... 1423.l2649 The most important thing to get your head around is the timing. Have a good read through the instructions on here http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=8326 Don't follow a Haynes manual as it has detrimental errors in it. If you are confused or have any questions just ask so you have everything in you head beforehand and are well prepared. When it comes to it Just take your time and double check things before moving on. If you are unsure of something while in the process of doing it then just ask as we are here to help. If your lucky there may be someone in the Lincoln area that will be willing to lend a hand
I like that. Russian roulettebut dont play roulette
Re: worried
get it done, stopper or manuals !
mine ran perfectly, sounded as sweet as a nut, then failed under no load at all in a car park outside the mot center.
you get absolutely no warning at all
- thumperslaw
Re: worried
Got manuals in mine
Best thing since sliced bread
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
K100 "flying brick"
Re: worried
If you do go the stopper route make sure you follow this link to set up the valve timing:-
http://www.vtr1000.org/phpBB3/viewtopic ... 31&t=19416
