Caliper piston seal quality question
mik_str
Post by mik_str »
Hi gents,
anyone ever use replacement seals from this seller:
http://www.ebay.com/itm/BRAKE-CALIPER-S ... 337aead6ce
Thanks in advance
scrowe
Re: Caliper piston seal quality question
Post by scrowe »
For the most part seal are seals. I've used OEM seals and aftermarket seals and if fitted properly with proper red heat proof grease you are fine! the dealers will say get the "real" ones but its the same rubber!
I stripped and rebuilt a set of 6 pot calipers on my exup1000 and the after market ones were bang on a cost nowhere near as much.
don't know that seller though.
