Clip ons
leevtr
Clip ons
Post by leevtr »
Right, I would be interested in raising the height of my bars, but don't want to go down the flat bars route, as I want to keep the look as is. Nor do I want to start butchering the fairings, so I know that limits things to a point. Anyone else using aftermarket clip ons, how much difference does it make, and what ones are you using. Had my eye on some adjustables on the bay, but thought I'd ask before taking a punt on them. I know vfr's fit, and later storm ones are a little higher, not sure they'll make enough difference.
Ta.
Re: Clip ons
Have you had any interest shown in the bike as yet Lee?
leevtr
Re: Clip ons
Post by leevtr »
Kev L wrote:Have you had any interest shown in the bike as yet Lee?
Few calls but jokers and dreamers mostly, so I'll keep it for now. Tbh I would rather keep it and get a second bike, but we'll see.
Re: Clip ons
How much do Vara's go for? Are they as bad at holding their value as the Storm?
Re: Clip ons
you could try those gb moto ones that keep the original clip ons, but use a spacer to raise them by a couple of cm's...
http://www.ebay.co.uk/itm/H-BAR-RISERS- ... 20c632d3a7
never used them myself tho...
darkember
Re: Clip ons
Post by darkember »
To get the height your after then you will need to trim the fairing.
Re: Clip ons
Unless you spend some ££££ Hell Bars. I could be wrong but I don't think they require fairing trimming.
Stratman
Re: Clip ons
Post by Stratman »
cybercarl wrote:Unless you spend some ££££ Hell Bars. I could be wrong but I don't think they require fairing trimming.
If they are as high as other bars the fairing would need to be trimmed just the same.
Re trimming the fairing, all you really need do is trim back the pieces that "drop down" as it were, which I think results in a cleaner more modern fairing line anyway. Some work with a dremel and a file/sandpaper and jobsa good'un.
Steve6088
Re: Clip ons
Post by Steve6088 »
You could avoid having to trim the fairing if the angle of the clipons are changed.
I'm using the dan moto adjustables to get clearance for cbr900 forks.
http://www.ebay.co.uk/itm/Adjustable-CN ... 611&_uhb=1
Good bars but I changed all the 6mm bolts with longer ones so I could put a nut on the end as the thread is easily stripped before the clamps are completly tight. Other than that they seem a good option
leevtr
Re: Clip ons
Post by leevtr »
After having a second look at this trimming situation, I've decided to order a pair of these......
http://www.ebay.co.uk/itm/200854493986? ... 1423.l2649
.......And do a bit of plastic removal if necessary. They're not higher per say, but I should be able to angle the bars almost flat, without totally losing the sports bike look.
Wish me luck !
lumpyv
Re: Clip ons
Post by lumpyv »
leevtr wrote:After having a second look at this trimming situation, I've decided to order a pair of these......
Wish me luck !
shiny! :thumbup:
make sure you bung some photos up when they are on .
thumperslaw
Re: Clip ons
Post by thumperslaw »
I brought some and they where higher then stock but still had -6 angle on them. For me they where to high
http://www.vtr1000.org/phpBB3/viewtopic ... 30&t=27038
98 storm with goodies!
Srad seven fiddy stuntbike
K100 "flying brick"
R.I.P engine number 5
