well done in completing the stoppermr.john.coates wrote:My contribution to this after just doing it:
1 - The dimensions of the locking tool in the Haynes manual are wrong I think. Make the tang (the business end) 3mm shorter else it won't lock. The proper dimensions are in the Honda workshop guide available on the forum.
2 - The stopper can be made from 8mm diameter bar - I used the plain part of an M8 bolt shank cut down. They will work out at about 11mm long each.
3 - You need a 2mm pin punch to get the roll pins out. Not having one I used the shank off an old 2mm drill ground off square.
4 - Do take the generator access plug out first - if you can't remove this easily you can waste hours faffing with it. Accept it'll get ruined and plan for replacing it.
Mr. J
just a comment for those following incase they can see a potential shortcut and do theirs at 11mm.........depending on your engine the stopper length is going to vary, I have seen them as small as 8mm long and as lond as 12, so dont think 1 size fits all. You have to measure each one and make the stopper to suit
