seb421
Post by seb421 »
nothing to the bikes but took everything out the garage, swept the floor out, hoverd it, swept it some more, then painted it white
went to the tip with old carpet and rubbish
waited for paint to dry, then fitted new suzuki blue carpet on top :D
fitted shelving racks on the right and loaded them up and sorted stuff out ready for the new arrival
cliveyandrews
Post by cliveyandrews »
Kev L wrote:Fitted the SP oil cooler and braided lines to the bike. Glad to see the back of the solid, rusting chrome lines!
Also fitted some new alloy exhaust hangers to replace the chrome steel Scorpion originals which again rust to buggery.
Kev - what did you do for bracketry on the SP cooler?
Still - I did strip left hand switch gear down, contact clean & WD40 - now dip switch and RH turn don't need a dozen stabs to make them work. New sweatband on M/Cyl, washed off road salt and lubed the chain. Not incredibly productive, but still 3 hours well spent....
Sent from my iPhone using Tapatalk and my fat thumbs...
Audi, Vide, Tace
cybercarl wrote::Hungry: :Hungry: :Hungry:
The only problem with them is they you can't stop eating them because you get the munches. It's a viscous circle. :lol: :lol:
I tried drinking Castrol R once, after the first taste I couldn't stop...it was a viscous circle.
Lol
We need to get a macV2 vs tony.mon joke off section :lol:
The thing is Mac's jokes are so bad we have to feed him material. :biggrin
cybercarl wrote:The thing is Mac's jokes are so bad we have to feed him material. :biggrin
Nah I'm alright not long had me breakie.
whitestorm pete
Post by whitestorm pete »
after abit of banging and swearing i got all the new bearings and seals put in me black swing arm then fitted the modified lower linkage and plated chain adjusters. got a day off work in a week or so should be able to fit the whole thing then.
If sh1t were money you would be worth a fortune
Virt
Post by Virt »
Currently stuck into the stopper mod. Have a question, do I just pull the spark plugs out? I cannot see any place for a tool but they're too stubborn to come out :(
Got the front cap off... Don't think I can reach the actual spark plug with anything short of psychic powers though, and I can't find the rear one. Haynes Manual, Y U NO HELPFUL
DO NOT FOLLOW THE HAYNES WHEN DOING THE CCT'S.........
Spark plugs, you will either need an 18mm deep socket and you may get lucjy and the outer circumference of the socket will slide down or get yourself a 12mm plug spanner. You should have a plug spanner in the toolkit under the seat if you have one. A magnet is also handy for lifting the plug out once it''s undone.
As for CCT''s follow the instructions for the stopper and timing in the workshop knowlagebase here. :thumbup:
Virt
Post by Virt »
I wasn't following the Haynes I was finding the spark plugs. Both out and corroded so that's another job that will need doing soon. Where are the two caps for the alternator housing? I'm following sirch's guide in the workshop knowledgebase but as someone with little mechanical knowledge apart from that I gained from watching my dad I'm stuck. :(
Is it the thing underneath the LHS fairing? With a huge allen bolt in the middle and a smaller one to the left? If so, don't I need to remove the surrounding bolts first?
Step 6 of http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=8326
Generator cover caps. The great big silver one in the centre with the allen key hole and the smaller one to the left.The centre one gives you access to the flywheel bolt so you can turn the crank and the smaller one allows you to see the timing marks. :thumbup:
Hopefully you have no problems removing them, especially the centre one otherwise you will be after some of these.
http://www.vtr1000.org/phpBB3/viewtopic ... 77#p222077
Image[/quote]
very jealous of your garage seb, i'd love one, whack the radio on, a small heater for winter....... :thumbup:
seb421
Post by seb421 »
It used to be a lot bigger mate intill my had a had a bathroom built at other end used some of the garage space, keep thinking about moving that garage door forward about four foot to the wall, extra four foot of space would be nice, used be able get four bikes in the garage can only get two now
Radio got stolen by my brother never to be seen again, as per usual lol
Fitted zx9 footpeg (£13) to accommodate my 'stiff' leg on the left side. Used the exhaust mount point on the hanger to gain a drop of an inch, and rotated the gear lever one notch on the spline. When leg gets better it will be easy to revert back to normal.
Idea borrowed from here: and made spacer tube from a on old plug spanner.
http://www.superhawkforum.com/forums/ge ... ing-26144/
'scuse filthy bike.
