black radiators
burty
black radiators
Post by burty »
i`m thinking of spraying my radiators black to try and make them look slightly less obvious from the side of the bike has anyone done this and if yes is there any pics of the end result :beer: :think:
Flatline
Re: black radiators
Post by Flatline »
I will post up a picture today and this is where you can get the paint from
http://www.frost.co.uk/eastwood-radiato ... rosol.html
Re: black radiators
Flatline
Re: black radiators
Post by Flatline »
There you go
burty
Re: black radiators
Post by burty »
Flatline wrote:There you go
nice thats what i hoped it would look like will be spraying mine up as soon as i get chance many thanks for the pics bud :thumbup: :beer:
Re: black radiators
i used frost radiator paint, quality stuff but not cheap....... :thumbup:
burty
Re: black radiators
Post by burty »
bigspanishmarty wrote:i used frost radiator paint, quality stuff but not cheap....... :thumbup:
gonna have a butchers in halfords later see whats in there :beer:
Flatline
Re: black radiators
Post by Flatline »
Marty has mentioned frost, which is the link I put in
The paint is by a company called eastman
As it is aluminium you should use the correct undercoat before any topcoat
They do this paint specifically for radiators in order not to interfere with the cooling
It sprays directly onto the aluminium
Using normal paint may not be worth the savings
burty
Re: black radiators
Post by burty »
Flatline wrote:Marty has mentioned frost, which is the link I put in
good point bud :thumbup:
Re: black radiators
+1 on using paint specifically made for radiators. It pays off in the long run :thumbup:
Re: black radiators
one can of frosts rad paint will do about 6 rads easy i've slao done my oil cooler.... :thumbup:
also take of the protective grill and do them aswell. tbh the rads are cheap and nasty with bits of weld stuck to them, i took the time to rub them down as much as possible before painting them, the frost rad paint is very good and easy to use, very good quality indeed...... :thumbup:
i also bought there exhaust paint, but i wasn't as impressed with it.... :(
Re: black radiators
Be careful removing the grill though as it has tabs on them that can easily snap, so go easy and don't be too heavy handed.
Re: black radiators
cybercarl wrote:Be careful removing the grill though as it has tabs on them that can easily snap, so go easy and don't be too heavy handed.
yeah, but i have spares ones already sprayed satin black, surprise suprise they happen to be for sale, be as heavy handed as you want buddy... :D
burty
Re: black radiators
Post by burty »
im just gonna spray the things whilst stil on the bike to be honest :thumbup:
Re: black radiators
be very very careful of overspray, you will still need to take off the criss cross mesh if you want a decent job mate. i did a little bit of spraying with the rads still on the bike, i taped/newspapered up where needed, the next day i found overspray on the forks and front mudguard.....grrrrrrr!!!!
Last edited by agentpineapple on Sat Apr 13, 2013 9:57 pm, edited 1 time in total.
