rough running
tattoo
rough running
Post by tattoo »
After having his vtr into the dealer with the dreaded cct failure my mate says since he got it back it won't rev past 7k and cuts out too and is running rough, apparently the machanic left the tps unconnected so he reconnected it but it's running rough, I've told him to recheck the timing and check the fuel tap for the stopping at 7k problem and to check for any splits in the vacuum pipes, check the carbs are seated properly and balance the carbs, clean the airfilter and to turn the idle up to 1200-1400rpm....have I forgotten anything????
Re: rough running
Sounds like timing is 180' out .
Re: rough running
Because of the rough running I would double check the vacuum pipe is connected on the right place on the petcock first just to rule it out. But because it's actually cutting out at 7 though this leads me to think this is another timing issue with it being 180 degrees out as Lloydie said.
You will find the solution in the following post:
http://www.vtr1000.org/phpBB3/viewtopic ... es#p259219
tattoo
Re: rough running
Post by tattoo »
thankyou guys...the timing was the first thing that come to mind,hopefully the dealer will have it right for him today.
Stratman
Re: rough running
Post by Stratman »
You would have hoped that a dealer would know this, wouldn't you!
Re: rough running
Tattoo, If you not already seen it, here's the correct procedure for setting the valve timing:-
http://www.vtr1000.org/phpBB3/viewtopic.php?f=31&t=8326
tattoo
Re: rough running
Post by tattoo »
thanks chris but it wasn't for me,i was just checking that i'd not forgotten anything
Re: rough running
No worries Tattoo. Any news on your mates bike yet :?:
tattoo
Re: rough running
Post by tattoo »
yes...i told him how to check the timing himself and suprise suprise it was 180 degrees out so i told him to send it back to the dealer as they did the timing after his front cct failed,hopefully it'll come back sorted..
Re: rough running
Good to hear your mate is getting somewhere at last, fingers crossed it comes back right this time :)
Re: rough running
sirch345 wrote:Good to hear your mate is getting somewhere at last, fingers crossed it comes back right this time :)
+1 :thumbup:
