Fairing lower
Fairing lower
Anyone any recommendations to which fairing lower to fit for good fit and quality? Any comments on pros and cons? Only a thought at the moment! Got lots of things I want to do over winter, until then just want to ride the wheels off it Cheers
Re: Fairing lower
Powerbronze brilliant
- Redthunder
Re: Fairing lower
Moriwaki replica (or genuine!!!)
Re: Fairing lower
Whichever lower you decide to get you may want to get some heat reflective foil sheet for the inside especially towards the rear as it can get a bit hot and melt some lowers.
Re: Fairing lower
I will testify to that one, mines got melted and having to repair it, fibre glass patch and mesh to reinforce the damaged area.cybercarl wrote:Whichever lower you decide to get you may want to get some heat reflective foil sheet for the inside especially towards the rear as it can get a bit hot and melt some lowers.
Re: Fairing lower
Lower fairing or bellypan, the best ones are made using fibreglass.
He's a link for the Skidmarx bellypan:-
http://www.skidmarx.co.uk/honda/50038-v ... y-pan.html
Re: Fairing lower
+ 1seb421 wrote:Powerbronze brilliant
Never argue with idiots. They drag you down to their level then beat you with experience!
Re: Fairing lower
I have a Powerbronze as well. The only thing that is not so good with them is being able to read the oil level in the window. I ended up using a cone cutter and making a hole and fitting a grommet in it.
Re: Fairing lower
Thanks for all opinions and suggestions, food for thought over winter months. Andy.
