CLUTCH LEVER QUESTION
Has anybody found a solution to the rather heavy clutch (lever) of the Firestorm, considering its hydraulic?
IE. May be used a different master cylinder!
- Stormin Ben
- Fireman on a Storm
Re: CLUTCH LEVER QUESTION
Mate, if you're finding it heavy, you may need to replace the rubbers in your master/slave cyl. I've never heard anyone say it's heavy.sirch345 wrote:Has anybody found a solution to the rather heavy clutch (lever) of the Firestorm, considering its hydraulic?
Larry.
'99 YELLOW
A man goes to the Zoo, but when he arrives there's only a dog.
It was a Shitzu!
'99 YELLOW
It was a Shitzu!
I must dissagree, my clutch is heavy and after ten mins or so of filtering traffic on the motorway my arm is in agony, all that on off with the clutch really pumps my arm up, no way is it light., got to admit i had a bandit 600 b4, with a cable cluch, but the storm is deffinitly heavyier on the wear and tear on the hands and forearms. mines is am 02 model, if anyone is interested
cheerz
kev
kev
I'm glad to hear its not just me, that's when I notice it, the same as you, when you are useing it a lot, on the open road no problem!kevg wrote:I must dissagree, my clutch is heavy and after ten mins or so of filtering traffic on the motorway my arm is in agony, all that on off with the clutch really pumps my arm up, no way is it light., got to admit i had a bandit 600 b4, with a cable cluch, but the storm is deffinitly heavyier on the wear and tear on the hands and forearms. mines is am 02 model, if anyone is interested
I only use my clutch for between 1st and 2nd. quickshifting most of the timesirch345 wrote:Has anybody found a solution to the rather heavy clutch (lever) o
If you find any spelling mistakes, you can keep them.
Clutch
Chris, Kev
I have an 02 bike too and think the clutch is hard work around town / after a long ride.
Have just recently changed the fluid but no real difference, shouldn't need nee seals alraedy should it?
Ben said - 'You could try moving the bar clamp further up the handlebars so you're using it closer to the end (more levereage = less force required) '
Not sure what this means, could anyone explain further.....
wrist ache
wrist ache
T00lkit
Red F2, Scorpion Race Cans, Nuvo Airflow Screen, GSG Moko Crash Protectors, Carbon Hugger by Del, Scottoiler.
- Pete.L
sirch345 wrote:Its the one in the middle PetePete.L wrote:Errr! is that the one on the left or the right???Has anybody found a solution to the rather heavy clutch (lever)![]()
And i thought that was the choke
Seriously now.
It might be worth removing your slave cylinder before you go and spend any money.
All the grease and grit that gets caught in it, off the chain, can build up and the push rod which goes into the gearbox might need cleaning off or (and I know there is a protective cover for you smart asses out there) the crud can penetrate around the actual piston itself. So get you self a big bottle of "Engine Gunk" and give the lot a good degrease.
Once it's all clean see if you have any improvement. Oh! and remove the cluth lever and strip the grease and replace it with some new that should help a little.
See....I'm not just a pretty face I KNOW STUFF TOO
