Nickcv
Post by Nickcv »
Got around to fitting my rear hugger :D
Nickcv wrote:Got around to fitting my rear hugger :D
don't forget to post some pictures of your modifying progress nick.... :thumbup:
it all adds to your post count.... :wink:
AMCQ46 wrote:Good work Carl and Hawk :thumbup: Wouldn't have guessed that...
It's just that I have been around these bikes for too long as I had seen the problem before. 8)
The funny part is a guy on the US forum had the same issue but didn't believe me and I believe he ended up selling the bike. :confused
Redthunder
Post by Redthunder »
Collected paint and spent evening flattening panels 8O
98 'Storm
16 Kawasaki Z1000sx
95 CB500r
98 Vfr800
00 Zx6r
Destined4bikes17@gmail.com
Spent the day with Ole Red and the Yellow thingy. Turns out it's French :roll: Got the subframes and swingarms swapped over. Pretty much the whole rear ends. I had a one armed bandit to help get in the way and do some light tinkering.
8O
seb421
Post by seb421 »
Yesterday Disabled the Exhaust Valve on the GSXR, when removing the wire from the ECU plug found some cowboy instead of pulling it out the plug had just cut the wire in the past
when putting it back together and the original can back on the wire had just been twisted back together and a bit of tape on it 8O no solder or anything
Sorted out the idle and fast idle speed too, ordered a new genuine filter and iridium plugs
Bike rides better now the valve is disabled, its louder a lot louder feels a different bike and sounds completely different under 6k
Ordered a new Genuine Suzuki air filter and iridum spark plugs too :thumbup:
Just got the news that my shock is going to ship out today........
So next week I get to ride :thumbup:
Guess I better get to work on changing the bearings in the Gilles rearsets so I can pop those on also......
Removed the barrel off the KH125 and took it and the 1st oversize piston off to PJ engineering to get it rebored.
Don't you just love 70's air cooled 2 strokes, how simple they are to take apart...
Quess how many bolts had to be undone to get the barrel off?
That good news, it about time. :thumbup:
Four
cybercarl wrote::
Four
Nope....you need to go up a bit, remember to factor in removing bodywork and inlet / exhaust.
Nine.
Could you slide the top off without removing the lump.
cybercarl wrote:Nine.
Too high now :D
lloydie wrote:7 :-)
Correct...
Removing the tank...0, it just sits on rubbers
Removing the carb...0, it's a disk valve engine so the carb is on the crankcase
Removing the exhaust...2 bolts on the barrel and 1 that joins the header to the silencer
Removing the head...... 4
Removing the barrel....0, it's held on with the long studs tat hold the head
=7 :thumbup:
