Look Mum, no standard undertray!
- Redthunder
- Redthunder
Re: Look Mum, no standard undertray!
Why didn't you just cut down the original and fit over the top mate?
i didn't feel the construction of that aftermarket one adequate to carry the tools without worrying going over a speed bump and them cracking the plastic so just did the cut down and place over method plus keeps the ECU / CDI where it was
here's where i cut mine incase you decide to change it mate, keeps the lock housing etc too
http://www.vtr1000.org/phpBB3/viewtopic ... ay#p259353
- Smokinjoe73
You can acually make a nice box in there out of sheet metal. Mine can carry a 4 foot kryptonite chain and huge armored padlock, plus tools.
Givi wingrack,CBR600 dash,CBR1000 forks, corbin, mario nava carbon fairing, 2bro carbon cans, vista cruise, GSXR mirrors.
- Redthunder
Well observed that man...Smokinjoe73 wrote:You can acually make a nice box in there out of sheet metal. Mine can carry a 4 foot kryptonite chain and huge armored padlock, plus tools.
Actually it is a battery box. I wanted to do something custom and not just "it'll do!".
Note also the Ecu and other electrickery are mounted on a custom cross member.
Also 2 small spigots welded on underside of subframe to locate the undertray better. Fits pretty well.
Will powder coat in winter.
As for tools they can go in the side pod. I tend to carry a small backpack anyway.
Sen my undertray doesn't have the little triangle plate holder at the back like yours.
I originally cut the tray in half then thought sod it I'll make a battery box.
- Smokinjoe73
I like your work, but would be concerned about the jarring shockwaves now going directly to the ecu/black box. Those things are isolated from solid frame members for a very specific engineering reason.
Seems like their lives will be shortened by an order of magnitude (approx). So I guess dont stray too far from home
- Redthunder
They are mounted as standard in rubber cases on plastic pegs on the standard undertray. Mine are still in the rubber cases and are still 'suspended'.Smokinjoe73 wrote:I like your work, but would be concerned about the jarring shockwaves now going directly to the ecu/black box. Those things are isolated from solid frame members for a very specific engineering reason.
If anything mine are mounted better because the standard ones are stacked...
