Will starter motor from 900 hornet fit a storm?
Post by Image »
Just bought one from ebay and hoping it will fit without any complex modifications.
benny hedges
Re: Will starter motor from 900 hornet fit a storm?
Post by benny hedges »
you may just need to swap the end cover and gear over m8
vtrjames
Post by vtrjames »
the part number for the starters are different but the o ring seal to the engine is the same and so is the brush sets so dimensions must be similar, probably wont have too much trouble fitting it by the looks of it.
good luck hope it fits straight in :thumbup:
Post by Image »
Modifications are't my strong point so wish me luck :cool2
vtrjames
Post by vtrjames »
aye youll be fine, just if you have to swap bits over you need 10 hands to put the brushes back in lol
Post by Image »
Post by Image »
Honda Hornet fitted a treat. Bolted straight on. Needed a couple of washers on the bolts but otherwise a perfect fit. Works a treat. Big thanks to Wicky for the heads up on that one. Average cost of storms starters with pp on ebay £90, average cost of hornet starters with pp £15. AND the hornet ones are less corroding. Me well pleased with Wicky.
darkember
Post by darkember »
I believe the Blade ones fit also & cost £20 up
frudd28
Post by frudd28 »
I put one on mine off a blade alot cheaper than the storm ones
