Tps, carb balancing, dyno.
Hi all, would it be best to set my tps before balancing carbs and a bit of dyno time? Cheers, Andy.
Re: Tps, carb balancing, dyno.
Do a carb balance/sync the carbs before adjusting the TPS as it it is directly connected to the Butterfly which affects the reading. And yes sort the TPS out before going to a dyno. Are you just going for a single dyno run or are you having a dyno tech work on your carbs or what.
Will be getting carbs balanced and a bit tech time if required!cybercarl wrote:Do a carb balance/sync the carbs before adjusting the TPS as it it is directly connected to the Butterfly which affects the reading. And yes sort the TPS out before going to a dyno. Are you just going for a single dyno run or are you having a dyno tech work on your carbs or what.
You don't need a dyno to balance the carbs, matey......Just a cheap carb balancer.
Yeah I'm aware of that thanks matetony.mon wrote:You don't need a dyno to balance the carbs, matey......Just a cheap carb balancer.
Thanks for that
. So I'm thinking get a cheap carb balancer, do my own, set tps then off to dyno?? Andy.
Why are you going on a dyno? Have you fitted a K&N/jetting kit/race cans?Wattys1 wrote:Thanks for that. So I'm thinking get a cheap carb balancer, do my own, set tps then off to dyno?? Andy.
Own peace of mind that mixture etc is all ok I suppose! Only recently bought it and its got scorpion cans and at some point had a k&n fitted, although its now running a standard filter.Stratman wrote:Why are you going on a dyno? Have you fitted a K&N/jetting kit/race cans?Wattys1 wrote:Thanks for that. So I'm thinking get a cheap carb balancer, do my own, set tps then off to dyno?? Andy.
- Redthunder
These things are brilliant. Used mine (on a Sakakaki) many times to great effect.darkember wrote:Cheap & bullet proof balance kit:
http://www.ebay.co.uk/itm/UNIVERSAL-MOT ... 6134225%26
On the shopping listdarkember wrote:Cheap & bullet proof balance kit:
The point I am making is that unless you have a Dynojet kit, there isn't much that can be done on a dyno that can't be done in the normal fashion.Wattys1 wrote:Own peace of mind that mixture etc is all ok I suppose! Only recently bought it and its got scorpion cans and at some point had a k&n fitted, although its now running a standard filter.Stratman wrote:Why are you going on a dyno? Have you fitted a K&N/jetting kit/race cans?Wattys1 wrote:Thanks for that. So I'm thinking get a cheap carb balancer, do my own, set tps then off to dyno?? Andy.
my local dyno place does £10 power runs on saturdays, well worth it to see what your a/f is like, your bike has probably been tinkered with by the p/o. so a cheap power run is a good idea, don't go paying £30/40 tho. just make sure your tyres are inflated properly and all your fluids are topped up. also the standard filter is fine, you can see gains with a k&n filter but it will need proper setting up on a dyno to iron out the flat spot.....
let us know how you get on dude.
Yeah that's the plan mate, then I know everything is right for my own peace of mind. Will be taking it to Paul at dynobike in Malton, he set up my zx6. Highly recommendedagentpineapple wrote:my local dyno place does £10 power runs on saturdays, well worth it to see what your a/f is like, your bike has probably been tinkered with by the p/o. so a cheap power run is a good idea, don't go paying £30/40 tho. just make sure your tyres are inflated properly and all your fluids are topped up. also the standard filter is fine, you can see gains with a k&n filter but it will need proper setting up on a dyno to iron out the flat spot.....![]()
