Rear shock length
Rear shock length
Can anyone tell me the measurement hole centre to hole centre of standard set, standard rear shock. Mine is fitted with a Penske with ride height adjuster and just want a base setting to work from. Cheers, Andy.
Re: Rear shock length
345mm springs to mind from memory, i'm sure someone will be along to confirm though.
popkat wrote:345mm springs to mind from memory, i'm sure someone will be along to confirm though.
346mm is the number I had but should be close enough
Same here8541Hawk wrote:popkat wrote:345mm springs to mind from memory, i'm sure someone will be along to confirm though.
Thanks for that. Gonna have shock and forks re worked over winter anyway
