New Exhaust Sleeves
New Exhaust Sleeves
I have an old set of Art cans sitting in the garage that have a few dings on them. I had an old stainless sleeve from an old project that I never used and used it to re sleeved one of the Art cans last week just as an experiment.
I must say it looks good but it got me thinking would a Carbon sleeve be up to the job of a big V Twin pumping through it. Would it split the carbon over time?
I know Lloydie had issues with one of his cans splitting.
Anyway, pros and cons please and what would you choose.
Jazz
Jazz
Everything good is bad
Everything bad is good
Re: New Exhaust Sleeves
If I was to build some I would use some of that heat proof lagging on the inside of the carbon .
I also think a well packed carbon can will last years before it needs doing again .
But heed the warnings if the carbon sleaze starts getting hot it needs packing
If the Carbon is properly fastened, with a metal band of some sort on both sides where it's riveted or bolted, and properly packed/repacked it will work just fine... But I'd say doing it as a DIY project though, I'd choose Stainless, it would be so much easier, without those pitfalls... Or perhaps aluminium, if you can swing that...
What about Ti sleeves? I know PJ engineering list them but I have no idea of the cost.
Kev L wrote:What about Ti sleeves? I know PJ engineering list them but I have no idea of the cost.
Would be interesting to find out cost,I did notice them on the site.
Jaz could you not get the ti sleeves rolled again to remove the dents ?
Now that is a question I don't have the answer too.lloydie wrote:Jaz could you not get the ti sleeves rolled again to remove the dents ?
Where would do such a thing and how much would it cost?
I will ask the guy tomorrow where I'm taking mine toJazzscot wrote:Now that is a question I don't have the answer too.lloydie wrote:Jaz could you not get the ti sleeves rolled again to remove the dents ?
Use a dolly.Jaz could you not get the ti sleeves rolled again to remove the dents ?
A barbie dolly !
Jazz, what was the idea behind using carbon sleeves rather than stainless steel
weight or looks?
Tbh weight isnt a consideration as I am of the larger build anyway.
Pretty much esthetics mate.
now have black front forks and a black lower and thought black zorsts might look nice.
Seeing as that's the case, and I don't know if this possible, but a carbon sleeve over the existing sleeve would be the best option,Jazzscot wrote:Tbh weight isnt a consideration as I am of the larger build anyway.
