Hi guys
I am selling just the viper can in the pic it is brand new never fitted bought a week ago from Brooks Barn for £72 with out link pipe. I paid £14 for the link pipe and also comes with strap.
Got to be worth £50 delivered?
Thanks
Round Alloy Viper Can and Link B/N £50
Moderator: VTRDark
Last edited by robby_firestorm on Tue Aug 13, 2013 11:37 am, edited 4 times in total.
2000 Firestorm
Re: Single Exhaust Front Pipe
have you got a picture or two fella, it'd be nice to see what your selling....
Re: 2-1 System Viper Can
Is that an actual 2-1 header pipe system? And is the exhaust a firestorm specific one?
Sent from my GT-I9505, written in ASCII using an even parity bit and spoofing the IP of the White House
It's a stock header with one link pipe blocked off and welded, you can see the "dead end" in the picture... Much like other people have done...Virt wrote:Is that an actual 2-1 header pipe system?
It works perfectly fine if not leaking, but needs to have the carb's tuned to run right, since it changes the back pressure compared to using two cans significantly... The result is less mid range torque, and a peaky power band, with more top-end power than otherwise... Should be good for a track bike, or if you just like the looks or changes to the power band...
GLWS...
Hi
Yes the end was closed and welded and I bought the exhaust last week from brook barn stated for firestorm for £72.25 with new exhaust strap. I paid £20 for the viper link pipe separate on eBay it has part number CN 201 on the packaging.
Hope that helps
Hope that helps
2000 Firestorm
