cb1300 wheels
cb1300 wheels
Will SP2 and possibly CB1300 wheels fit the SP1 ?
I have noticed that CB1300 wheels look identical to SP2 wheels, does anyone know if they are the same ?
I like the gold wheels on the cb1300 and wonder if they would fit an SP1, although I don't think the abs wheels will .
Re: cb1300 wheels
I like the cb13 5 spokes wheels I've asked a local beakers to lend me a set if he ever gets a set in so I can have a play :-)
Re: cb1300 wheels
SP1 and SP2 wheels are interchangeable, no worries
As for the CB wheels, I don't know but would assume it is set up to run the smaller 25mm axle so you might need to source bearings and possibly spacers.
Re: cb1300 wheels
I've got a set.....attached to the cb1300 swingarm, frame, and engine !!lloydie wrote:I like the cb13 5 spokes wheels I've asked a local beakers to lend me a set if he ever gets a set in so I can have a play :-)
Re: cb1300 wheels
When you get a chance could you take some measurements please
Re: cb1300 wheels
Apart from that, they look pretty much identical, so it's entirely possible that they are so, despite different part-no... I'd say it's highly likely, as Honda is known to re-use things...8541Hawk wrote:SP1 and SP2 wheels are interchangeable, no worries![]()
Re: cb1300 wheels
What do you need ?lloydie wrote:When you get a chance could you take some measurements please
Re: cb1300 wheels
Front Spindle size.
Front disc size
Disc spacing (between the discs)
Rear
Outside Sprocket to out side disc.
Spindle size
Inside disc to wheel Centure and the same with sprocket .
Please no rush tho .
Front disc size
Rear
Spindle size
Re: cb1300 wheels
Not much then...lloydie wrote:Front Spindle size.
Front disc size
Rear
Spindle size
While you at it Lee can you come round & cut me grass...
Re: cb1300 wheels
Spindle sizes being thickness I assume ??lloydie wrote:Front Spindle size.
Front disc size
Rear
Spindle size
Re: cb1300 wheels
Awkward to be absolutely bang on with dimensions without removing the wheels, but these will be very close.lloydie wrote:Front Spindle size. The only bit I can get to without removing the wheel is the wider exposed end ( not the nut end ). 25mm
Front disc size. As near as dammit 315mm. Again, to be spot on wheel needs removing.
Disc spacing; (between the discs) Inside to inside 132mm
Rear
Outside Sprocket to out side disc. 210mm
Spindle size. 22mm measured at threaded end
Inside disc to wheel Centre. 74mm ish. and the same with sprocket . 116mm ish.
Re: cb1300 wheels
Very good but what about my bloody grass ?leevtr wrote:Awkward to be absolutely bang on with dimensions without removing the wheels, but these will be very close.lloydie wrote:Front Spindle size. The only bit I can get to without removing the wheel is the wider exposed end ( not the nut end ). 25mm
Rear
Re: cb1300 wheels
Thank you lee I will jot them down and have a think at the week end
Re: cb1300 wheels
It wont be yellow when it's ready to roll...leevtr wrote:Dont talk to people with yellow bikes
Mind you weather I'll be able to roll with it is open to question...
Anyway wont be much point in talking I wont be able to hear you over the noise of the mower...
