bike won't start
Re: bike won't start
darkember wrote:
lloydie wrote:Sounds about right :-)
Tony is used to a yellow one and they are considerably faster than a blue one
Well everything will be faster that the green one :lol: :lol:
Yep as I'm having to drip feed it oil ATM :-( but wait till next year when it has the mc'engine in it (from a red one) so it will be supersonic in 2 seconds :-)
carmanbikes wrote:Have you had the tank off by any chance when doing the dyno run, I had the tank off and left a vac pipe off the tank when putting it back on :(
thats not the issue buddy, we've checked all that..... :(
if its from the red/black bike, i think the more important figure is supersonic to 0 in zero seconds........ :lol: :lol: :lol: :lol:
(sorry mac)
Lol yep that one but he had the galaxy drive on ,onto into you want to put what where !
It behaved perfectly on the funeral run, once I'd bolted the numberplate on, started on the button, didn't miss, fuelling wasn't perfect but near enough to ride, can't think what this might be.
Side stand is the logical culprit but I always thought that cut the ignition so you wouldn't get a spark....
The sidestand switch rarely fails entirely, it just gets enough slack in teh pivot so that the switch cuts connectivity at times (usually over a bump) or permanently. The easy way to check is to take it apart, clean it and operate it by hand when off the sidestand.
You should be able to meter it for connectivity.
I'm away at Beautiful Days festy this weekend or would offer to have a look for you.
no worries tony
as carl said, if you'd noticed a problem you would have either tried to fix it or told me about it. and i agreed with him. i haven't got time to look at it just yet, if i get the chance i'll have another go at it on thursday.
we'll get it sorted i'm sure..... :thumbup:
Does it have petrol in it ?
a/ no...there's your problem.
b/ yes...problem solved, open the cap & stick a burning rag in it...
MacV2 wrote:Does it have petrol in it ?
Yep now where's that vid of it blowing up :-)
yeah yeah we know, you don't like the bike, or its colour, much less its owner......... :wink:
Just trying to give you a helpful hint or two in your hour of need...
As for the Yeah Yeah...It's a Storm so I like it...It's blue, so what colours just a colour not fussed really, just it's fun to take the pee...It's owner...well no comment on that one... :lol:
all sorted..... :thumbup:
me and the cyberman fitted a new loom(sebs old loom), which also includes a datatool alarm which was nice......... :wink:
we had to stop halfway thru after hearing a massive crunch from outside the back door, it turns out one of my neighbours had rear ended the car in front of him whilst trying to park his people carrier, he hit it so hard he ended up smashing 3 cars, as he forced one into the other and so on, the last car that was hit stopped less than an inch from the back tyre of carls bike.... :eek2 :eek2 :eek2
that was lucky for carl, if we hadn't have rushed out, the fella would have walked off without telling anyone, in the end he left notes on the cars windscreens.
the major downside is the last car to get shunted forward is now across my nans back door, so I can't even take the bike out for a ride... :(
if it isn't moved tomorrow i'll have to contact the police to get it moved, i'll doubt they'll be in a rush to move it tho.... :roll:
agentpineapple wrote:all sorted..... :thumbup:
Well done, good work Carl... :lol:
So did you find anything wrong with the old one ?
As for the car in the way...put the window through & take the handbrake off & push it...simples.
darkember
Post by darkember »
As for the car in the way...put the window through & take the handbrake off & push it...simples.[/quote]
Would be interesting to find out what bit failed on the old loom for future reference
darkember wrote:Well done, good work Carl... :lol:
Would be interesting to find out what bit failed on the old loom for future reference[/quote]
we never stripped the loom to find the problem, our money is on the wires going into the top ecu box, because it was unattached and bouncing around the undertray, we think the wires going into were damaged.
as for the car blocking the back gate, in the accident the front wheels have been turned inwards toward the wall, so even putting the window thru wouldn't help, as the steering lock will prevent me from steering the car out of the way..... :(
Hairy biker
Post by Hairy biker »
Nice one glad you got it sorted :thumbup:
Of all the things I've lost I miss my mind the most
