Help! Brake caliper pin!
pmcq
Post by pmcq »
Hello All
Right then, I think I could be in trouble... :roll:
In the process of wanting to remove my brake pads, I have managed to round off the end of the pin that goes thru the caliper and holds the brake pads in place. Its not totally roundeded but allen keys seem to slip with applied force. I even managed to snap an allen key trying to open it up. I have sprayed abotu half a can of WD40 into the bugger and it flows through but still no movement - if I get my hands on the mechanic who tightened it up...why I outta...
Anyway I've also tried hacksawing the other end of making a small slot so I could use a screwdriver. This hasnt worked... Please tell me it not time to take the drill out :? I have some good news - I do have a replacement pin so I dont care what happens to the old one!
Any ideas anyone!
pmcq
Stormin Ben
Post by Stormin Ben »
Maybe apply a bit of heat to the pin, then let it cool down again, might loosen it
Other options
1) angle the allen key slightly. By this I mean if you look at it from the side instead of being in line with the pin its slightly out of line. Makes a tighter fit
2) Get the next size up allen key (imperial ones are favorite coz they're fractionally bigger/smaller) and hammer it into the bolt
3) File a couple of flat spots on the pin and get the b8stard wrench out
4) Finally, cut it off as close to the head as you can so you can get the pads etc out before setting too with the drill
Hope this helps
Ben
yellafella
Post by yellafella »
A torx bit might be better, hammered into said allen bolt ? the hammering , etc might be just what it needs ! Not too heavy though ! You dont want to do any damage to mounts !
pmcq
Post by pmcq »
Cheers Lads!
Time to get the hair dryer out :-))
