Now that makes a lot of sense.It's the worn sprocket which does most of the damage to the chain so if you use the best you can find you'll also get the most life out of your chain.
As Pete L said, you'll be better of with a steel sprocket for road use (or at least steel teeth on an alloy sprocket as some companies produce),bigtwinthing wrote:has anybody used "Talon" aluminium rear sprockets before!!! i have a 43 tooth Gold (yuk) rear sprocket to try? any idea what there like??
Supersprox, but they cost more. I have heard one argument that because of the extra expense for the Supersprox then one may just as well buy two ally ones.(or at least steel teeth on an alloy sprocket as some companies produce),
Just like the rest of it except the carbs lolcybercarl wrote:I'm looking forward to giving everything (especially behind the sprocket cover) a good clean and get rid of all the muck. It's never been touched since I've had the bike.
