ABBs
And they give a better feel as there is less or none bulging in the lines .lumpyv wrote:I always thought braided lines reduced fade when being used hard?. otherwise not much difference ?
Braided lines improve the feel/reduce sponginess, brake fade is caused by the brakes overheating hence the fade if being used hardlumpyv wrote:I always thought braided lines reduced fade when being used hard?. otherwise not much difference ?
If they are bleed properlyBraided lines improve the feel/reduce sponginess
the early blade calippers are black and are the same as the storms front and back .cybercarl wrote:I see you have the standard master cylinder as well. Maybe the callipers are CBR Callipers.Have got anything ground off them to make them fit the mounting point.
+ 1lloydie wrote: The standard front brakes when kept in a good serviceable condition are good
