Chain and sprockets
Re: Chain and sprockets
I like the Muc off PTFE based lube.I also carry a small pocket sized can under the seat.
oh do you now...........cybercarl wrote:I like the Muc off PTFE based lube.I also carry a small pocket sized can under the seat.
i'd check your cush drive rubbers whilst your at it carlos.....
I have no lube atm so will try that stuff outcybercarl wrote:I like the Muc off PTFE based lube.I also carry a small pocket sized can under the seat.
Cush drive rubbers... If they are worn would they give the feeling of play through the chain as you let the clutch out? As if the chain & sprockets are turning a couple of degrees before the drive reaches the wheel?
Jamie
- bigtwinthing
Yep and feel a slight "bump" when throttling off.Jamoi wrote:I have no lube atm so will try that stuff outcybercarl wrote:I like the Muc off PTFE based lube.I also carry a small pocket sized can under the seat.
Who mentioned Cush drive.
I don't think mine are too bad really. Nothing that warrants buying new ones anyway. If I need to and there is any wear in the blocks, I shall just pack them out with some plastic.
wedge some tescos carrier bags in there hahahahahacybercarl wrote:Who mentioned Cush drive.I don't think mine are too bad really. Nothing that warrants buying new ones anyway. If I need to and there is any wear in the blocks, I shall just pack them out with some plastic.
Hahaha I might try and stuff some pants & socks in the gaps! It's worked in the past
Since I've renewed my C&S's it feels like my Cush drive rubbers are worn
the bump is there too off the throttle, thanks for confirming. Will change them soon.
Jamie
let us know where you get them from, I will need to get some fresh ones for my bike in the near future, iirc d.s sells originals for just over £40Jamoi wrote:Hahaha I might try and stuff some pants & socks in the gaps! It's worked in the past![]()
Since I've renewed my C&S's it feels like my Cush drive rubbers are wornthe bump is there too off the throttle, thanks for confirming. Will change them soon.
buy the best you can (oem) as they will last a lot longer than the cheaper crap .
i brought mine from honda for my blade and did 5k on them and fitted the old ones when it went.
i then fitted them in the vtr and now 15k later they are still good .
so for an extra £10-15 its worth it .
Ok cheers, makes sense to go for originals. I'll have to wait till after op storm though as I've just brought air filter & plugs
Funny, I didn't notice the worn feeling before I changed C&S's... ??
Jamie
Try shimming the cush rubbers with cut up placcy from ice cream containers (benny tip no. 48)
Jamoi wrote:Ok cheers, makes sense to go for originals. I'll have to wait till after op storm though as I've just brought air filter & plugs![]()
I will DEFINITELY try this! I like cheaper solutions like this
Thanks
Thanks
Jamie
That's what I'm doing.
Rolls eyes > http://www.urbandictionary.com/define.p ... lls%20eyes
http://forums.appleinsider.com/t/21377/rolleyes
http://dictionary.cambridge.org/diction ... -your-eyes
I do like the rolly eyes emotion, but I don't use emotions appropriately half the time. You've heard of trigger happy, i'm smiley happy
No offence meant wicky. I added it because I mentioned using plastic earlier.
