Chain and sprockets
Re: Chain and sprockets
I like the Muc off PTFE based lube.I also carry a small pocket sized can under the seat.
cybercarl wrote:I like the Muc off PTFE based lube.I also carry a small pocket sized can under the seat.
oh do you now........... :lol: :lol: :lol:
i'd check your cush drive rubbers whilst your at it carlos..... :thumbup:
I have no lube atm so will try that stuff out :)
Cush drive rubbers... If they are worn would they give the feeling of play through the chain as you let the clutch out? As if the chain & sprockets are turning a couple of degrees before the drive reaches the wheel?
bigtwinthing
Post by bigtwinthing »
Yep and feel a slight "bump" when throttling off.
Who mentioned Cush drive. :roll: I don't think mine are too bad really. Nothing that warrants buying new ones anyway. If I need to and there is any wear in the blocks, I shall just pack them out with some plastic.
cybercarl wrote:Who mentioned Cush drive. :roll: I don't think mine are too bad really. Nothing that warrants buying new ones anyway. If I need to and there is any wear in the blocks, I shall just pack them out with some plastic.
wedge some tescos carrier bags in there hahahahaha
Hahaha I might try and stuff some pants & socks in the gaps! It's worked in the past :D
Since I've renewed my C&S's it feels like my Cush drive rubbers are worn :( the bump is there too off the throttle, thanks for confirming. Will change them soon.
Jamoi wrote:Hahaha I might try and stuff some pants & socks in the gaps! It's worked in the past :D
let us know where you get them from, I will need to get some fresh ones for my bike in the near future, iirc d.s sells originals for just over £40
buy the best you can (oem) as they will last a lot longer than the cheaper crap .
i brought mine from honda for my blade and did 5k on them and fitted the old ones when it went.
i then fitted them in the vtr and now 15k later they are still good .
so for an extra £10-15 its worth it .
Ok cheers, makes sense to go for originals. I'll have to wait till after op storm though as I've just brought air filter & plugs :)
Funny, I didn't notice the worn feeling before I changed C&S's... ??
Try shimming the cush rubbers with cut up placcy from ice cream containers (benny tip no. 48)
Jamoi wrote:Ok cheers, makes sense to go for originals. I'll have to wait till after op storm though as I've just brought air filter & plugs :)
I will DEFINITELY try this! I like cheaper solutions like this :D
Thanks
That's what I'm doing. :roll:
I do like the rolly eyes emotion, but I don't use emotions appropriately half the time. You've heard of trigger happy, i'm smiley happy :) No offence meant wicky. I added it because I mentioned using plastic earlier. :thumbup:
