I might not be able to repair this one.
Re: I might not be able to repair this one.
WTF it looks like it's melted. 8O
Phimosis
Post by Phimosis »
Trying to save petrol and running it lean huh?
She told me she was 16.
That's what happens when three out of four valves drop into the combustion chamber.
That's not melting, that's proper mechanical hell on earth, that is....
macdee
Post by macdee »
:Jaw Drop:
And it's bleeding. :lol:
cybercarl wrote:And it's bleeding. :lol:
It's bleeding expensive.....
So what do you recon happened to fu k it up that bad? Can't see why high comp or tuning would do that
Off the top of my head there was some valves, and half a piston.
Cams were ok, cam journals and cam chains also, manual cct's fitted, of course, and valve timing was still set, so I'm thinking either valve spring float leaving opposing valves able to touch each other, or maybe a valve collet or two coming loose, literally dropping a valve.
Once one's gone, everything else joins in.....
darkember
Post by darkember »
tony.mon wrote:Off the top of my head there was some valves, and half a piston.
Would the added heating during the London trip have had any bearing on the consequences??
bigtwinthing
Post by bigtwinthing »
"course grinding paste"
Styler4077
Post by Styler4077 »
Take the piston out and run a 500cc Storm. :)
I do want to see the piston when (If?) it comes out.
Any bits make their way past the piston to the crank?
Good luck any way Tony
"Only one life, so live it and ride a motorcycle"
so are your cam profiles so much more aggressive than normal.........given that you haven't raised the rev limit that can be the only reason for valve float.
but if it is a collet coming loose than is that an assembly issue or a design weakness.
as you can tell I like to know root cause before I would build a new engine, otherwise what is to stop the new one doing the same?
warby221
Post by warby221 »
Looks like you had a valve head shear there tone
Only ever seen that a couple of times usually on competition motors or extreme over-revving
Buggers just seem to wave a white flag and give up then do all sorts of damage banging around
First time I’ve known one make it out the engine and in to the exhaust
So you’re looking at head and pistons defiantly shot
Good chance of con rod and bearing damage and a few floating bits off ally finding their way to the parts other bits cannot reach
When you think about what a valve go's through at 10K revs it’s amazing more don’t fail really
Bet it made a hell of a racket when it went
warby221 wrote: Bet it made a hell of a racket when it went
Let's put it this way- I was in no doubt that I was going to need another engine........ :lol:
I was just surprised that nothing came out through the cases!
warby221
Post by warby221 »
lol i bet a case of
sphincter on standby
its brown trouser time
