Heres my step by step im tryin to keep it simple as we all know how to take the fairing off ect......
First job is to check current lights aim as I know this passed the mot, take a pic for reference and make sure you put the bike in the same position when you check the new unit aim.
Standard units aim
2. Removing the headlight unit from fairing by the 4 screws.I had trouble removing the screws because some wombles retard had used superglued as thread lock! The lower 2 i removed after cutting a grove across them and pouring boiling water over them and using a flat bladed right angled rachet screwdriver there were many choice words and at one point i thought I was gona lose it !! then had to epoxy resin one of the gromets back into the fairing that the screws fit into.
3. Once you have freed your headlight its going to need heating in the oven to loosen the silicon. read the next sentence twice because this is where people go wrong and ruin there headlight housing.
Pre heat your oven to 180c then TURN IT OFF! its the turning off part people have not done. once the oven is
OFF!
Place the headlight on a teatowel and place in the oven for 5mins.
4. Using a large flat blade screw driver pry the 2 halves of the unit apart.
5.This is to your own preference but I primed the now redundant reflector with some acid etch then a coat of satin black. I did wonder if you had one of the slower red, yellow etc coloured bikes if it would look good to spray the reflector to match.
With the projector fitted (make sure that the straight edge of the solenoid is going to be level, i did this by eye looking through the projector without the HID bulb in)
