There is no way that the mechanic (I think so if I got it right) messed up the timing becouse he only adjusted the clearance!! He didn't remove the cams or something. According to the quoted post!! So it must be the a/f mixture!
Enough with the theory. Sorry for all the fuzz! I would like to thank you all for being so kind with yr help!! I'll start wearing my woking rob tomorrow afternoon or Sat morning and get the jobs done!! Will post pictures!!
All they need to do is turn it to tdc rear cylinder (no need to touch the front one) with the cams pointing up and towards each other, then remove the cam caps and cams, then holding the cam chain loosely to stop it jamming round the crankshaft, rotate the engine anticlockwise one full turn at the crank, until RT is lined up once more.
Then fit the cams, with lobes pointing up and towards each other as before.
