Bits wanted to complete my refurb
Standard side stand
Right side radiator bracket (the one that bolts on engine)
Plastic undertray (front cylinder under carbs)
That's it for now many thanks
Bits wanted
Moderator: VTRDark
Bits wanted
Re: Bits wanted
Might have the rad bracket leave it with me & I'll check a bit later & then let you know.gabi81 wrote:Bits wanted to complete my refurb
Standard side stand
Re: Bits wanted
Yep I have both sides.
The shorter of the two is the right hand bracket.
Both look straight & true compared up against the ones on my bike.
Both are a bit crusty but so are mine, nowt a bit of elbow grease, wet n dry & a bit of paint wont cure.
Buy both for £10 +postage.
R/H on its own...£350 +postage...
Nah only pulling your leg...£5 +postage for R/H only.
Re: Bits wanted
Let me know full price with postage and send me a PayPal thanks
Re: Bits wanted
Got the triangular undertray/heat shield.
£10 posted? (most of that will be postage...)
Re: Bits wanted
ok now i need a front right caliper as the thread on one bolt is gone off....so will need it complete with bolts
thanks
thanks
Re: Bits wanted
Got a pair, I don't think I want to split them, though.
Re: Bits wanted
do they work ok or need doing up?tony.mon wrote:Got a pair, I don't think I want to split them, though.
and how much?
