Riding in town, the temperature increased to 110°C = 230°F.
The fan did not start.
When I reached home, the temperature increases to 112°C = 233°F and I stopped the bike.
The "cooling tank" rejected some antifreeze per its higher hose (1/4 liter) with a little sound like "blubblublub" near the "thermostat".
I switch the key on with motor stopped: the fan didn't start, temperature at 112°C-230°F.
I waited until temperature decreased to 110°C (230°F) and restarted the bike.
The fan does not started until it reached 112°C (233°F) and then started.
Then temperature decreased to 110°C (230°F) then fan stopped and the temperature reincreased to 112°C (233°F) then fan restarted and so on.
Usually, the fan starts at 108°C-226°F (that is high my taste) but today, it started at 112°C-233°F and I lose some antifreeze.
What should I check ?
bleeding cooling system ? Replace Thermocontactor on the radiator ?
Thermostat ? Too much cooling antifreeze ?
I've checked antifreeze level last week and it was precisely at the "full" mark on the "cooling tank"
