Oh god, don't do that or I'd never start it up at all.leevtr wrote:Sounds good, but when fuel and time are factored in............Jamoi wrote:I got 2 front brake lines, with black coated braid, a handful of copper washers and a cuppa for £20 iirc. I tipped them a tenner.
The only problem I can see if doing what I did, but over the phone, is getting the right bends on the fittings and getting the offsets right before clamping.
If you can find a place to walk into locally, I reckon it'll make life a bit easier!
Sounds like a lot of aggro, but when you see the savings over buying x4 branded lines...
4 Line kit ??\
Re: 4 Line kit ??\
Re: 4 Line kit ??\
Well it's up to you dude, but hosequip are 5 mins away from me & I'd happily watch some pro's at work for 15 mins.leevtr wrote:Sounds good, but when fuel and time are factored in............Jamoi wrote:I got 2 front brake lines, with black coated braid, a handful of copper washers and a cuppa for £20 iirc. I tipped them a tenner.
Let us know what you go for.
Jamie
Re: 4 Line kit ??\
Jamoi wrote:Well it's up to you dude, but hosequip are 5 mins away from me & I'd happily watch some pro's at work for 15 mins.leevtr wrote:Sounds good, but when fuel and time are factored in............Jamoi wrote:I got 2 front brake lines, with black coated braid, a handful of copper washers and a cuppa for £20 iirc. I tipped them a tenner.
Sent from my GT-19505 using Telekinesis![]()
Might give them a call tomorrow.
Re: 4 Line kit ??\
Might give them a call tomorrowJamoi wrote:Well it's up to you dude, but hosequip are 5 mins away from me & I'd happily watch some pro's at work for 15 mins.leevtr wrote:Sounds good, but when fuel and time are factored in............Jamoi wrote:I got 2 front brake lines, with black coated braid, a handful of copper washers and a cuppa for £20 iirc. I tipped them a tenner.
Re: 4 Line kit ??\
Are you modding your posts I'm getting lost in the quotes.
Re: 4 Line kit ??\
Hey! when did Hosequip move as they used to be 5 minutes from me - Funny place when it used to be on Hythe Hill as they until quite recently and might still be using a vintage Mac running OS 7 or 8 to run their stock database system. Plus when I grew up next door to them when they were in Spurgeon St I regularly kept smashing their windows playing cricket in the road….
Re: 4 Line kit ??\
Wow blast from the past. System 8 was the first OS I officially bought. An ideal use for old Power PC.Mac running OS 7 or 8 to run their stock database system.
Re: 4 Line kit ??\
