Need a piece of steel tube.....
leevtr
Post by leevtr »
....Of sufficient strength and diameter to knock my lower steering bearing down. Anyone know where to get some, or have a bit already, and fairly local. Only need to do the last 5 mm, but the stuff | have isn't man enough and I'm losing he will to live with it.
Re: Need a piece of steel tube.....
if you have some universal axle stands for your car [or if a neighbour has] the upper section of that works a treat.
also don't put a block of wood between the hammer and the tube as it absorbs to much of the initial impact and the brg stops moving before it is bottomed out
lee,
2 more obvious bits of wisdom tha ti guess you have already done, but pays to check.
use the old bearing as a spacer/cushion between the drift and the nice new bearing.
oh and you did remember to fit the lower seal didn't you?
I ended up using a big adjustable wrench and hitting that, moving the jaws around every couple of whacks so the bearing went on evenly. Otherwise riding around and going over a few bumps will knock things into place, then re adjust the tension.
Using the old bearing upside down on top of the new one.you can grip the lower yoke and old bearing in a vice and use the vice to do the work.
Apply pressure to one side then the other.
Just before the new bearing is completely seated, centralise the seal; once it's home you won't be able to move it.
Easy, effortless and you don't hit your fingers with hammers.
I was going to ask Chuck Norris to tell the bearing to just get on.. but ended up using an old hoover tube and lube
When I did mine I got Tony to do it.
Worked a treat.
Didn't bash me thumb once... :lol:
darkember
Post by darkember »
Use the inner race of the old bearing and a piece of tube that will slide onto it. You wont find a tube to fit exactly onto your new bearing, been there before.
leevtr
Post by leevtr »
AMCQ46 wrote:lee,
lol, yes seal in first, and dont have a vice ( coming soon, although by the time I build a bench and buy a vice I wont bloody need it )
ging500
Post by ging500 »
Jamoi wrote: ended up using an old hoover tube and lube
Don't want to know what you get upto in spare time
Tweety
Post by Tweety »
It's even easier to just use the but at the top and a big washer over the pipe if needed... No hammers involved... Just smoothly tighten down the pipe and bearing...
Image <--- The result of OCMD... I gave up listing the mods in a sig line...
