Front Stand.
- bigtwinthing
Front Stand.
Hi
Anybody recommend a front stand so that i can take the forks and wheel out? ( they will be off to Roger soon i hope?) regards Paul.
Re: Front Stand.
Have you got a car jack?
Or something to hang the bike from? Garage joists or the like?
Jamie
Re: Front Stand.
Try a ratchet strap if you have a good beam. (rear on paddock stand)
"It may be yellow but it ain't no chicken"
- bigtwinthing
Re: Front Stand.
Jamoi wrote:Have you got a car jack?
i have a jack etc, sadly no roof beam as it stays in my garage but it has a glass roof, as it is built on from the conservatory,
problem is the dog, horse, daughter and wife all walk through there and i don't want it being knocked over!!! Fook that sounds posh but it aint!!!
Re: Front Stand.
Front Headstock Stand
http://www.ebay.co.uk/itm/310226107466? ... 1423.l2649
Though the variety of headstock pins that came with the stand aren't big enough for the storm - so using the smallest 13mm one and fitting a 17mm ½" socket does the job and ensures clearance underneath the fairing.
Re: Front Stand.
If you get an abba stand, you can do your rear shock (as per your other thread) and do your forks with the Abba stand and jack under sump.
Any good?
Any good?
Jamie
- bigtwinthing
Re: Front Stand.
Wicky wrote:Front Headstock Stand
just bought one from that thread Ta.
- bigtwinthing
Re: Front Stand.
Cheers just bought a front stand, my mate will lift the bike up to do the shock ta. (hiab) etc i hope i get it nowJamoi wrote:If you get an abba stand, you can do your rear shock (as per your other thread) and do your forks with the Abba stand and jack under sump.
Any good?
- bigtwinthing
Re: Front Stand.
bigtwinthing wrote:Wicky wrote:Front Headstock Stand
what do you fit rear stand then front?
- turbo_billy
Re: Front Stand.
Most definitely rear first.......
- bigtwinthing
Re: Front Stand.
turbo_billy wrote:Most definitely rear first.......
Ta i was hoping i may have sussed that out, has anybody seen the bobbins that fit just inside the rear axle shaft and can be used with rear stand lifting hooks?
Re: Front Stand.
Buy an abba stand mate. You were asking what to spend a grand on, 100 on this would be a good long term investment. They now do an attachment which raises the front as well, but if you have a ground anchor and a ratchet strap, this will also work. Anyone here with an abba will tell you the same, worth every penny !!
Re: Front Stand.
+1 , mine's a self made copy of the Abba, best thing everleevtr wrote:Buy an abba stand mate. You were asking what to spend a grand on, 100 on this would be a good long term investment. They now do an attachment which raises the front as well, but if you have a ground anchor and a ratchet strap, this will also work. Anyone here with an abba will tell you the same, worth every penny !!
Re: Front Stand.
Have you lads seen the attachment for the Abba Stand. Can easily make one, it gets the front off the ground. Saw them at the NEC.Jamoi wrote:If you get an abba stand, you can do your rear shock (as per your other thread) and do your forks with the Abba stand and jack under sump.
Any good?
Theres A Hare in The Turnips.
Re: Front Stand.
Ah. Sorry never got as far as your post Watty, you've covered that equipment
