Running them on the "Legends" SP and, again, they do everything you want them to do. Stick well and never had any cause for concern.TonyW650 wrote:Has anyone tried Maxis Supermaxx Diamonds?????
Yes, I do rate and recommend Maxxis
If they are ok on your Sp, then they should be ok on the buell lolturbo_billy wrote:Running them on the "Legends" SP and, again, they do everything you want them to do. Stick well and never had any cause for concern.TonyW650 wrote:Has anyone tried Maxis Supermaxx Diamonds?????
They say the Diamonds can take a bit of getting used too as when you take the lean angle onto the Diamond area, they "squish" a bit as the pattern spreads. Never found it to be a problem myself, in fact never noticed any difference from a "standard" tyre. They reckon they give approximately 30% more contact area when they are cranked over.TonyW650 wrote:Just I asked on the buell forum and kind of got the answer, their cheap and crap!
I use maxxi supersports there okay i would say there just as good as any of the other tyres i have tried but dont cost the earth but there a bit like marmite you either like em or hat emturbo_billy wrote:Running them on the "Legends" SP and, again, they do everything you want them to do. Stick well and never had any cause for concern.TonyW650 wrote:Has anyone tried Maxis Supermaxx Diamonds?????
