I'm sure I had a drawing with dimensions etc for the linkage plates you need to make when carrying out the VFR800 single sided swingarm conversion on a Firestorm.
I have searched high and low but I can't seem to find it anywhere.
So before I go searching any further have any of you got a copy of it I can have please
VFR SSSarm linkage plates drawing?
Re: VFR SSSarm linkage plates drawing?
No drawing but I have the newly made plates in the car I will take a picture of later and measure tomorrow and up date this post .sirch345 wrote:I'm sure I had a drawing with dimensions etc for the linkage plates you need to make when carrying out the VFR800 single sided swingarm conversion on a Firestorm.
While ck is at mine tomorrow I'm going to finish off all the measurements for all the spacers so we can have a reference thread even tho it didn't get built :-( as it might be of use for someone one day , or if ck can't sell the arm before I decide to have it
Thanks Lloydie, that's a great idea, as you say it could be useful for others later onlloydie wrote: No drawing but I have the newly made plates in the car I will take a picture of later and measure tomorrow and up date this post .
I'm not intending to be carrying out this MOD anytime soon, but nice to have the info just in case. It's just annoying me where that drawing is, I'm sure I have it somewhere. The more I can't find it, the more I want to find it, if you know what I mean
Newly made triangle to clear the swing arm . You can see the bit remove to give full suspension travel .
And the standard one
Only 5 years
Are the three holes in the plate equal distance apart? I'm trying to make a new set of plates for my sssa conversion but am guessing at dimensions. If you could supply the measurements between each hole on the plate I can produce a drawing and store it for future.
I've almost finish the vtr project I'm working on, just need to powder coat the rear wheel and finish a bit of exhaust polishing after fettling the linkages on the shock.
