Yeah, you pay for the guy's time, not just per run.
He'll pull the airbox and carbs (in half the time you or I could do it, the bar steward) and swap out jets.
He'll do one set of runs, look at the readouts, then suggest some changes, carry them out, then another set of runs; chances are that if he's any good that'll be about right.
Then maybe trying something to see if it's better or worse, maybe another little change, with a run between each.
A good one will quote you about three to four hours, but won't take that long.
And boy, will you notice the difference on the ride home....
If you can, balance the carbs and fit new plugs before you go, and the valve clearances need to be in good condition, too. If they are due, get them done first.
Lastly, I would definitely advise against dyno runs if you still have unmodified standard Honda CCT's........
